yes it is normal I`ll try to find the big thread on the discusion of it here for ya
I tried the pwm trick by isolating it with rubber o-rings, it did not work, so I disconnected the electrical connection to the pwm valve so it could not run and still hear the ticking, I have found a very noisy injector on driver side number one with a stethoscope and have put a can of seafoam in to try and see if it will clean it out otherwise I may have to replace the injector. Other than that I am all ears if anyone has found the solution to this.Hey guys,
My 07 FJ has a ticking noise coming from the valve train at idle. I took it to the dealer and they service manager there said it's normal. Does any one else have a noise coming from their valve train?
Thanks!
