61 - 62 of 62 Posts
You are spot on!
Baja Designs LP6:
Forward Projecting Lumens: 8,600 Utilizing 6 LEDs
Forward Projecting Wattage/Amps: 90W / 6.5A
IPT Lumens: 1,700 Utilizing 4 LEDs
IPT Wattage/Amps: 15W / 1.0A
Backlight Wattage/Amps: 4.14W / 0.3A
The Contura SPDT switches are rated at 20 Amps, so they should be fine, but - i will call them at OTRATTW just to be safe.
P.S. did you put the amber backlights on a separate switch - or tied to your running or DRL's?
Discussion Starter #62
You are spot on!
Baja Designs LP6:
Cool. I used the turn signal DRL as the trigger to a relay, which draws power directly from battery to the amber backlights. But with this minimum draw, you should be fine just power directly from DRL. Note that the head light DRL are not 12V, it's basically low beam with a resister in series. So your amber back light will be dimmer if you power through those (they are already pretty dim...). I forgot if the turn signal are like this or it is full 12V.
61 - 62 of 62 Posts
