I noticed that my left axle seal is leaking again(shocking!) and just happened to grab hold of the inner cup where it goes into the front diff and noticed it had a bit of play in it when moved vertically and horizontally . I checked to see how much play was in the right hand side and it has a bit play but not as much as the left one. I was wondering if you guys know if there is a bearing in that area that could be worn out? I have a 2008 with 50k miles and I also have 3" lift with a diff drop and swaybar relocate kit.
