1 - 20 of 65 Posts
I compiled a list of some torque specification, capacities, requirements, and tolerances, etc.. Most, if not all, of this data was found on this site. I have not verified any of the data shown below. I assume no responsibility whatsover... use at YOUR own risk.
Common Torque Specs:
  • Engine Oil Drain Plug: 30 ft/lbs.
    Gasket: 90430-12028 or 90430-12031
  • Front Diff:
    Fill Plug: 29 ft/lbs.
    Drain Plug: 48 ft/lbs.
    Fill Plug Gasket: 12157-10010
    Drain Plug Gasket: 90430-24003
  • Rear Diff:
    Fill & Drain Plugs: 36 ft/lbs
    Gaskets: 12157-10010
  • Transfer case
    Fill & Drain Plugs: 27 ft/lbs
    Gaskets: 90430-18008
  • Manual Transmission
    Fill Plug.....27 ft-lbs
    Drain Plug.....27 ft-lbs
  • 5AT, Automatic transmission (A750F) :
    Trans. Pan DRAIN Plug : 15 ft/lbs (metal crush washer)
    Trans. Pan CHECK Plug : 21 ft/lbs (metal crush washer)
    Transmission FILL Plug : 29 ft/lbs (rubber O-ring on FiLL plug).
  • Wheel Nuts 113 N·m (11.5 kgf·m, 85 ft·lbf)
  • Drive/Propeller shaft bolts: 88 N*m (899 kgf*cm, 65 ft.*lbf)
    (u-joint flange yokes on both drive shafts: 65 ft. lbs.)
  • Spark Plugs: 14 ft/lbs
  • Ignition coils: 7.4 ft/lbs
  • Stock skids: 21ft/lb's
  • Skid Plate bolts - 25 ft/lbs
  • Brake Caliper - 110 ft/lbs
  • Body Mounts: 35 ft/lbs
  • Outer Tie-rod end (steering): Donahoe says 54 ft/lbs
  • Front Coilovers
    Top 3 bolts - Donahoe says 30 ft/lbs... Toyota dealer says 47 ft/lbs
    Lower Bolt (LCA): Toyota dealer says 100 ft/lbs
  • Front UCA
    Upper ball joint turning torque 4.5 N*m (46 kgf*cm, 40 in.*lbf) or less
    Long Bolts: Toyota dealer says 85 ft/lbs
    Spindle joint: Toyota dealer says 81 ft/lbs
  • Front LCA
    Lower ball joint turning torque 3.0 N*m (31 kgf*cm, 27 in.*lbf) or less
  • Front Stabilizer link ball joint turning torque 0.05 to 1.96 N*m (0.5 to 20.0 kgf*cm, 0.4 to 17.3 in.*lbf)
  • Rear Upper Control Arms bolts - 59 ftlbs
  • Rear Lower Control Arms bolts - 96 ftlbs
    Rear Stabilizer link ball joint turning torque: 0.05 to 1.96 N*m (0.5 to 20.0 kgf*cm, 0.4 to 17.3 in.*lbf)
  • Rear FJC shocks
    Upper nut: 18 ft-lbs
    Lower bolt: 72 ft-lbs
  • Rear anti-swaybar
    nut, upper link assy (frame): 11 ft-lbs
    nut, lower link assy (swaybar): 52 ft-lbs
    bolt, bracket cover (over bushing): 22 ft-lbs
  • Front axle
    hub nut x Front drive shaft 174ft*lbs.
ENGINE Oil capacity (2007-2009) (drain and refill), L (qt., Imp.qt.):
With filter 5.2 (5.5, 4.6)
Without filter 4.9 (5.2, 4.3)
Oil grade: ILSAC multigrade engine oil
SAE 5W−30
ENGINE Oil capacity (2010+)
6.0 qts. without filter
6.4 qts with filter change.
SAE 0W20
Transmission/Differential - 6MT (full−time four wheel drive models):
Oil capacity, L (qt., Imp. qt.):
1.8 (1.9, 1.6)
Oil type: Gear Oil API GL−4 or GL−5, SAE 75W−90
NOTE: Read before doing differential: http://www.fjcruiserforums.com/forums/maintenance-tech/60405-differential-gear-oil-tsb.html
  • Front Differential
    1.4 (1.5, 1.2)
    Above −18C (0F)
    SAE 90
    Below −18C (0F)
    SAE 80W or 80W−90
  • Rear Diff
    without rear diff lock- 3.0 liters / 3.2 qt. / 2.6 Imperial qt.
    with rear diff lock - 2.9 liters / 3.1 qt. / 2.6 Imperial qt.
    Oil type: Hypoid gear oil API GL−5
    Above −18C (0F)
    SAE 90
    Below −18C (0F)
    SAE 80W or 80W−90
  • Transfer Case
    1.4 (1.5, 1.2)
    Oil type: Hypoid gear oil API GL−5, SAE 75W−90
TRANSMISSION/Differential - 5AT (part−time four wheel drive models)
Fluid capacity (drain and refill)
L (qt., Imp. qt.):
Up to 3.0 (3.2, 2.6)
Fluid type: Toyota Genuine ATF Type WS
    1.5 (1.6, 1.3)
    Oil type: SAE 75W−90
  • Rear Diff
    Above −18C (0F)
    SAE 90
    Below −18C (0F)
    SAE 80W or 80W−90
  • Transfer Case
    1.0 (1.1, 0.9)
    Oil type: Hypoid gear oil API GL−3, 75W−90
_______________________________________________
CHASSIS LUBRICATION:
Propeller shafts:
[*] Spiders = Lithium base chassis grease, NLGI No.2
[*] Slide yokes = Molybdenum−disulfide lithium base chassis grease, NLGI No.2 or lithium base multipurpose grease, NLGI No.2
__________________________________________________________
ADD ENGINE COOLANT
(a) Tighten the 2 cylinder block drain plugs.
Torque: 13 N·m (133 kgf·cm, 10ft·lbf)
(b) Tighten the radiator drain plug by hand.
(c) Add engine coolant.
Standard Capacity:
Automatic Transmission
9.8 liters (10.4 US qts, 8.6 Imp. qts)
Manual Transmission
9.4 liters (9.9 US qts, 8.3 Imp. qts)
Spark plug:
DENSO K20HR−U11
NGK LFR6C11
Spark plug gap, mm (in.):
1.1 (0.043)
ENGINE:
Valve clearance (engine cold), mm (in.):
Intake 0.15—0.25 (0.006—0.010)
Exhaust 0.29—0.39 (0.011—0.015)
Fuel:
Fuel type:
Select premium unleaded gasoline with an Octane Rating of 91 (Research Octane Number 96) or higher for optimum engine performance.
Fuel tank capacity, L (gal., Imp. gal.):
72 (19.0, 15.8)
Engine Model:
4.0L V6 (1GR−FE)
Type: 6 cylinder V type, 4 cycle, gasoline
Bore and stroke, mm (in.):
94.0 95.0 (3.70 3.74)
Displacement, cm3 (cu. in.):
3956 (241.4)
Dimensions and weights:
Overall length mm (in.) 4670 (183.9)
Overall width mm (in.) 1905 (75.0)
Overall height*1 mm (in.) 1810 (71.3)*2mm (in.) 1830 (72.0)*3
Wheelbase mm (in.) 2690 (105.9)
Front tread mm (in.) 1605 (63.2)
Rear tread mm (in.) 1605 (63.2)
Vehicle capacity weight(occupants + luggage)
kg (lb.) 540 (1190)
Towing capacity (trailer weight + cargo weight)
kg (lb.) 2268 (5000)
*1: Unladen vehicle
*2: Two−wheel drive models
*3: Four−wheel drive mode
BRAKES
Minimum pedal clearance when depressed with the force of 490 N (50 kgf, 110 lbf) with the engine running, mm (in.):
54 (2.1)
Pedal free play, mm (in.):
1—6 (0.04—0.24)
Pad wear limit, mm (in.):
1.0 (0.04)
Lining wear limit, mm (in.):
1.0 (0.04)
Parking brake adjustment when depressed with the force of 196 N (20 kgf, 44.1 lbf):
5—7 clicks
Fluid type:
SAE J1703 or FMVSS No.116 DOT 3
STEERING
Wheel free play: Less than 30 mm (1.2 in.)
Power steering fluid type: Automatic transmission fluid DEXRONII or III
Thanks. Assuming the information could be, if necessary, modified here and a sticky based on.
Sticky status votes? All say "aye".
"aye"
Hey thanks! You're a lifesaver! I can delay paying for a subscription to the TIS for all that info! What years does this cover? Especially the oil filter torque specs since Toyota changed the filter type in the newer FJ's.:rocker:
Forgot to vote for my own call to vote, so "aye".
Discussion Starter #11
Great thread, it gets my vote to be a 'sticky' :clap: To get torque specs I've been using the FJ Repair Manual which has 843 pages to filter through to find torque specs. This thread definitely simplifies and saves a lot of searching time, much appreciated for posting. :cheers:
1.8 (1.9, 1.6)
    1.4 (1.5, 1.2)
    Above −18C (0F)
    SAE 90
    Below −18C (0F)
    SAE 80W or 80W−90
  • Rear Diff
    Above −18C (0F)
    SAE 90
    Below −18C (0F)
    SAE 80W or 80W−90
  • Transfer Case
    1.4 (1.5, 1.2)
L (qt., Imp. qt.):
    1.5 (1.6, 1.3)
  • Rear Diff
    Above −18C (0F)
    SAE 90
    Below −18C (0F)
    SAE 80W or 80W−90
  • Transfer Case
    1.0 (1.1, 0.9)
<snip>
Why is there such varying recommendations or information about the gear oils?
On the one hand there is a TSB that says Toyota currently recommends 75W85 GL5. Correct? Then right after that there are members recommending/using/quoting 75W90. WTF? If Toyota is recommending (and using) 75-85 why would someone recommend 75-90?
And the 80-90 for rear diff? Where does that come from? There's a whole bunch of other threads quoting 75-90 GL5.
There is a difference between 75-85, 75-90 and 80-90. More than some might think.
Is there a thread or post that has the difinitive information from Toyota or other reputable/reliable source for what the weight should be in the gear oils for the FJs? Since the OP says none of this info has been verified at all it seems kinda useless (ie - whether it is right or not).
To add to this list :
DEWFPO
Pardon me if this is already covered:
Should the first post be updated to show the correct oil capacity for the 2010+ FJ`s?
and correct grade of 0W20...
You tell em' Pale...:lol: 2010+ Represent!!!
So the actual Axle Nut torque should be - Crapload ft/lbs (think 186 ft/lbs)... Yet when I removed mine from the factory setting... barely had 50 ft/lbs on it. Broke it with a 12" long breaker bar and one hand...
Toyota needs to feed their techs some Wheaties... :lol: :rofl:
when you mentioned that, I found this:
Front axle hub nut x Front drive shaft 174ft*lbs.
man, I`d hate to read about a dude doing an oil service on a newer FJ and only adding 5+ quarts... yikes...:cheers:
1 - 20 of 65 Posts
