1 - 7 of 7 Posts
Hello all,
I have a 2014 FJ TTUE, and upon purchase had the dealer install the genuine Toyota tow hitch kit with 4-pin wiring harness kit. I'm considering purchase of an Xventure XV-2 off-road trailer but am wondering whether the stock Trail Teams suspension is up to the task or not:
The FJ is rated for towing 4,700 lbs if I remember correctly, while the maximum weight of the XV-2 trailer (loaded up to max capacity) is 3,500 lbs. I doubt that I'll ever have it loaded to 3,500 lbs but it's a good conservative number for planning purposes. Though the FJ is technically rated for towing this weight, how bad will it be on the stock Trail Teams suspension? I'm a little concerned about excessive sag, etc.
Additionally, I'll be installing a 7-pin RV hookup and brake controller since the trailer does have electric drum brakes.
Thanks for any help!
You will be fine with that set up. Worst scenario is that you are at 80% of tow capacity, which is the general rule of thumb not to exceed that number. Some airbags in the rear springs would help alot.
Reactions: SWITAWI
Not an issue as the tongue weight will most likely be around 500#. If you're really concerned though stop by a truckstop with a weigh scale and weigh the combination before you head out. That's the best way to know exactly where you stand.
I doubt you'll ever come close to 3500 lbs in the XV2......you'd have to be hauling rocks or something. I tow a 19ft travel trailer, with queen bed, full fridge, tons of gear, etc and it weighs maybe 3100 lbs, with a tongue weight of ~ 400 lbs. It tows just fine with my stock 08 TT suspension.
1 - 7 of 7 Posts
