1 - 20 of 119 Posts
Vendor
Toyota FJ Cruiser Reverse/Backup LED Bulbs! See Install Video & Comparison Photos!
Toyota FJ Cruiser Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your FJ's reverse light or backup light bulb (921 size). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two 921-sized LED bulb, for perfect fitment in all Toyota FJ Cruiser Models.
Bulb Design
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
Fitment. All three bulbs use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP5: (92 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern instant on/off of LED technology.
HP36: (210 lumens) Slightly higher brightness than OEM bulbs.
XP50: (410 lumens) Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Customer Reviews:
"Installed stage three (XP50) in stock light receptacle. Even with the high cost of these bulbs, they saved me a lot of money by not needing to install additional lighting on the rear of my FJ. I have seen numerous LED bulbs in the past and these are the highest quality I have seen. I have had for nine months now with no issues whatsoever. (Posted on 9/22/14)" -Jrope
"These bulbs were the first LED's I purchased from Diode Dynamics. I went with the modest HP36 and am extremely happy with them. If LED's are what you are looking for, you cannot go wrong with Diode Dynamics. (Posted on 1/25/15)" -Daniel
Re: FS: BRIGHT Reverse/Backup LED Bulbs! Hi-Power / CREE Models, Ships Same-Day
Where are you lights assembled,I know they were designed in Missouri.Just curious about where they were assembled.
Johnny
Vendor
Johnny
Johnny,
They are currently manufactured overseas. The only company in the U.S. that manufacturers their own bulbs is Putco (in Iowa)
We manufacture as many products in-house as possible
Nick C.
I'm unable to checkout. It keeps giving me a webpage not available error
The webpage at https://www.diodedynamics.com/store/onestepcheckout/ might be temporarily down or it may have moved permanently to a new web address.
Error code: ERR_CONNECTION_CLOSED
Can't sign up for an account either.
Vendor
It's working for me, could be a browser issue or a cached version of the site
Please give us a call at your earliest convenience and we can assist you in placing an order: (314) 205-3033
Thanks!
Nick C.
Hi guys, I am interested in these LED bulbs but I just have a few questions.
How much brighter are they than stock?
How many lumens are our stock reverse lights?
If these lights provide say 2x or 4x more light, will that affect visibility thru the backup camera?
Will the view be washed out or clearer?
It would help if a forum member has installed these and could show some before and after photos.
$70 seems like a lot of moola for a pair of reverse bulbs.
Take it easy!
Vendor
Discussion Starter #9
Take it easy!
Thank you for asking!
The factory 921 bulbs are around 200 lumens or so, depending on use (incandescent bulbs lose output gradually over time so that number varies)
The HP models produce 210 lumens and last considerably longer than the factory bulbs. Our XP50 bulb model produces 410 lumens (2x the factory brightness).
They are perfect for vehicles equipped with backup cameras, as they make it considerably easier to see while backing up. They won't wash out the camera or create any glare.
I understand your cost concerns, but our products utilize the highest quality LED chips in the production of our bulbs. This means we use only brand-name suppliers such as Cree, Epistar, Osram, and Samsung. Therefore, they are priced competitively with other well-known U.S. lighting vendors.
They also feature circuit designs produced in-house here in St. Louis, so they will be more reliable and longer lasting than other options on the market.
We also back them with a 3-year limited warranty, and our helpful customer service team
We've been looking for an FJ Cruiser to bring into our studio here in St. Louis for comparison shots, so I apologize for not having those pictures available yet (Coming soon!) but here's a recent comparison with a 2014 F-150 that uses the same bulb size as the FJ (921)
If you have any further questions or would like more information, please don't hesitate to give us a call: (314) 205-3033
Thank you!
Nick C.
Vendor
Discussion Starter #13
Will you guys ever have replacement mirror bulbs and will they ever have the option for amber?
The HP5 fits the mirror light and is brighter than the stock bulb. Just make sure you do the "diffuser removal mod". Not sure if the brighter bulbs are too long or not, but they will plug in.
Vendor
Discussion Starter #17
We will have LED replacements available for nearly every location on the FJ Cruiser once we have one in our studio for professional comparison shots.
The FJ Cruiser is very high on our list of priorities for early 2015, so expect to see more soon :grin
Nick C.
If you remove the diffuser film in the mirror lights you can fit just about any length replacement bulb in them.
All of my exterior bulbs, minus headlights and reverse bulbs, are from Diode Dynamics. I am completely satisfied with the LED's and customer service. I had a bulb that didn't work properly and they promptly replaced it with a new set. I would recommend these guys!
Vendor
Discussion Starter #20
Thank you!
We appreciate your support!
Really looking forward to getting comparison shots with an FJ Cruiser. Our photographer is very talented:
(I know it's a Jeep, sorry! lol)
Nick C.
1 - 20 of 119 Posts
