does any body know the turns ratio to inches eg. one complete rotation is equal to 1/4 inch of travel up or down the shaft. looking to install these today and i want to pre set them before i put them in.
but what about extra weight like ARB bumper and 9000lb winch? should i add an extra 1/4 inch to overall hight? i would like some actual numbers on this, not just guesses.3. As an estimation - the coilover collar moves up and down on the shock at a 2 to 1 ratio to the lift height. Trying to clarify my statement - If you move the collar down 1/2" the FJ lowers 1".
i should have added 3/4 of an inch, but as you can see, its alot more. i will be greatfull for any help and advice.3. As an estimation - the coilover collar moves up and down on the shock at a 2 to 1 ratio to the lift height. Trying to clarify my statement - If you move the collar down 1/2" the FJ lowers 1".
there is still another inch + of thred on the coller if you want to go higher, but with anything over 3" comes diff drops ect. thanks for the measurement. what do you mean byHow much taller can you go?
measured in front of the hub.
yes it will.and when you adjust it does it mess up your alignment?
what technique did you use to measureI am 23 1/4" from the middle of the hub.
Do you have stock UCAs?thank for the reply Tray, but what is this knocking coming from the drivers side, ball joints? it wasn't there before 6 hours ago.
With stock front bumper, mine is at 1 15/16" from the top of the bottom collar to the bottom of the top collar.here is what i thought of. measure from the bottom of the top collar to the top of the bottom collar. right now i'm set at 2 and 7/16 from inside to inside ( of the collars ) what do you 3" guys have? 3" with and without bumper and winch, if that makes a diff.
well i'm WAY OFF, by like half an inch. that would explaine it. thanks Tray thats what ill dial it down to in the morning. CASE CLOSED! someone should sticky those measurement.With stock front bumper, mine is at 1 15/16" from the top of the bottom collar to the bottom of the top collar.
Wow, you're almost 5/8" more than me between collars. I've got an older kit with the silver eibachs, so maybe that's the difference.With stock front bumper, mine is at 1 15/16" from the top of the bottom collar to the bottom of the top collar.
I'm guessing the bumper/winch wouldn't compress enough to make up for the 1/2" difference on the coilovers (1" difference in lift height).
I've been waiting on my bumper since Thanksgiving, or I'd have a apples vs. apples comparison for ya.
