1 - 5 of 5 Posts
Ok, I ebayed a wiring harness for teh FJ. I just got it today and I have to tell you, that looks very very complicated to hook up. I bought one for my acura and it was plug it in, route the terminal near the hitch and you were done. This is 6 connectors, a fuse, fuse holder with a yellow wire loop, cable I have to run from the battery to the back...What gives? Is this the right one? Is there a simpler one where I just plug it in and it's done with out having to install a fuse run wire, etc....?
Thanks,
Travis
There are two different types of harnesses. You probably got the one I have. It is a lot easier than it looks. If you didn't get the directions let me know and I will e-mail them to you. Mine is NOT the one that is linked in Constantines entry.
If it is the aftermarket one that says its for a Mazda then you need to go to the manufacturers website to download the directions, either way its pretty easy.
the other one looks very easy and more factory...I'm going to order one of those....
the one I have does say mazda on it. I know when I added one to my mdx, it was just one connection and I was done.
thanks guys...
Space
1 - 5 of 5 Posts
