1 - 12 of 12 Posts
Hello, new owner of an '08 FJC auto, 4x4, with 85k miles. Am noticing a strange bump feeling after coming to a stop at a light , and then accelerating. It happens about 30% of the time. Any ideas, or experiences like this?
Thanks for any help.
Very common observation with many Toyota trucks built over the last 15+ years. Most commonly caused by slight binding of the splines in the slip-joint in the rear driveshaft.
Lube the appropriate Zerk fitting every 5K miles with high-quality moly-filled chassis grease.
You will typically see a correlation between the abruptness of the stop and the tendency to get the “bumped from behind” sensation. If you do 99.5% of your braking and then let up slightly so you slowly roll to a final gentle stop, you will never encounter this, even if your slip joint is binding slightly.
I started experiencing this after 30K miles, but giving each zerk 1-2 pumps of grease every 5K has completely eliminated it
I know this is an old thread but it appears both toyota, and now Dorman, came out with a redesigned rear driver shaft to take care of this. Don't know if its worth the money as opposed to a few pumps of the grease gun every 5k miles. The Dorman pn is 936-773. Factory number appears to be 3711035A00.
Letting the transmission downshift by itself around 37 miles per hour and again at about 23 miles per hour, braking and rolling into a steady stop solves this problem.
I have the same problem, just started last week. I'm going to lube it up tonight. Thanks for all the replies...
I grease mine every 5K. It still has the bump. Its been doing it for over 13 years. Everything is fine and its not on my worry list :)
1 - 12 of 12 Posts
