301 - 314 of 314 Posts
Discussion Starter #301 (Edited)
Here it is! Drilling without a press and vice is the worst! I had to put the non fouler in vise grips then step on it and drill with flip flops. Took forever as I had to gradually go up sizes one drill at a time. You can see how I butchered the non fouler in the process. You know when you're breaking out in a sweat drilling (not that kind of drilling) you are most likely doing it wrong.:)
But it's done and here are some tips.
If you buy a 7/8's o2 socket you will most likely need one of them flex head ratchets. I didn't have a flexy ratchet handy so I cannot confirm. There's no space in there for an au regulaire ratchet.
I also used an electrical contact cleaner spray cuz I could quite get the plugs apart. Who knows if it helped make a difference but I got er apart.
Best price for this socket after checking multiple places was Harbour Freight.
A 7/8's box end wrench will fit over the o2 electrical plug so you can run in down the wire and get all the traction you need. See pic below for a little trick you can do with two wrenches to break it free. I didn't need to do this, this time but I had another wrench hand so I could do this in case.
So far it's been a day and P0420 error code has yet to rear it's stupid face.
A week without it and I'm gonna move on to other issues.
If you have any questions about this hack you can post here or PM me. As always disclaimer is use at your own risk.
Price breakdown again - Total cost for non foulers was $8 to bypass this issue. I did the research and the cheapest I could find an O2 sensor is $47 for the downstream followed by $120 for the upstream and after all that it could still be the cat itself for a nice juicy $291! Total $459.00 U.S. or $616 Canadian funds.
Lastly GREAT NEWS! A friend of mine that I got back in touch with sold his Mini, is currently in a Hilux and is planning to buy a V8 4runner or a newer FJ. **** is coming roses for me lately LOL!
Discussion Starter #302 (Edited)
Some thoughts about maintenance, specifically Engine Oil. IMO There is no reason anyone should be running any of their vehicles on regular engine oil.
This is why. There is always a sale on synthetic somewhere and all you have to do is do an occasional online search on an parts store web site. Just about any synthetic oil is gonna be better than regular but, of course try to stick with the better brands. Even the name brands go on significant sales... and sometimes to where it is the same price and even cheaper than regular oil.
Just make sure you have 2 large jugs of synthetic oil in your garage at all times and when you don't keep an eye out for sales. If anyone has a better method please chime in. Still learning as I go. And always keep a few drain plug washers handy.
Oh yeah, I also put in a little bit of ATP 205 every oil change as a preventative for my rubber gaskets.
Discussion Starter #303 (Edited)
Feedback and Help please
UPDATE: The O2 sensor hack has been solid. Great $6-$15 solution to an otherwise huge cost.
BUT unfortunately the next thing I worked on may cost me large.
The Oil sensor that sits next to the Engine Oil Filter was leaking so I did a bit of research and saw that we can throw in some thread sealant or thread tape to plug it up. I opted for some teflon tape. Bad choice it seems.
Unfortunately I cracked and stripped the housing or is it called the oil filter sub assembly? Can some thin tape along with heavy handedness cause this? See pic.
What are my options from here and is it pretty involved replacing it? I did a quick search but didn't come up with any part numbers unfortunately.
Discussion Starter #305 (Edited)
can you remove it and have a machine shop weld up and re-tap the hole for you?
That's a great suggestion but nothing opened this weekend. I tried the wreckers as well to see if I could grab the oil bracket sub assembly part but no luck. Lesson learned. Go buy the deep socket which BTW is a 15/16's for the Oil pressure sensor instead of cheaping out trying to use vise grips. In retrospect I think the pressure from the vise grips clamping down then me using too much pressure may have been the contributors.
Don't be like me. LOL!
Discussion Starter #307 (Edited)
FJ Cruiser Parking Drum Brake tips and tricks
This has to be one of the most challenging jobs I have done on the FJ and the difficulty is the sequence in which you add the parts to the wheel hub. Followed by the Shoe Hold Down spring which I spent 4-5 hrs on before my wife found the key searching the internet.
I did this b4 but I reused parts and because there was less tension it made the job easier. New springs make it near impossible without knowing a few little tricks.
A flashlight and having the printed diagram taped in my wheel well really helped.
To start-
Ensure you point your tires straight fwd. Chock the front wheels. Loosen the wheel lugnuts while the tires are on the ground. Leave the truck in Neutral and the parking brake off.
Jack the rear up and use 2 jack stands and leave the jack on the diff for safety. Remove the wheels.
You will have to remove the brake assembly to remove the rotor to get to the drum brake parts. For that you will need a 17mm socket.
The rotor may be stuck even though the parking brake is disengaged. Loosen the tension with the adjuster by screwdriver
To remove the rotor you will have to have your car chocked and the parking brake off and
After you have Brake-Kleened everything and laid out your new parts... the first thing to do is grab that small zap strap and compress the 2 cups and shoe hold down spring (the rear one.) After that put the pin in through the back of the wheel plate and position the shoe spring so it is secure – twist to semi secure it in that 90 degree positon
Note the orientation of the zap strap in the pic so the pin can fit through and be twisted the 90 degrees.
I snaked the zap strap out the adjuster access hole and held it in place hanging some vice grips before starting on the next part.
Next part to add is the Rear shoe. Start by attaching the brake cable and the address connecting the return shoe spring at the top. You will have to use a sturdy pair of pliers here. It helps to make room for the 2nd shoe spring by pushing the spring to the back with a screw driver.
Now that the top and bottom of the rear brake shoe is secure focus on the shoe hold down spring. I have been able to do this in 10 minutes and on another occasion it took 30 minutes. Use 2 long screwdrivers and also the zap strap (needle nose pliers) to help getting the pin into that slot.
Be patient with this. It is the most difficult part of the entire job. Need nose pliers holding the end of the zap strap along with a long thin screwdriver to guide makes it doable
Make sure you have that back cup washer secured in the hole on the brake shoe.
Prep the front shoe hold down spring with the zapstrap then the pin.
Next is the front brake shoe. But first place the Shoe strut and shoe string in it’s home on the rear brake shoe.
Put the shoe return spring on the front brake shoe first then you can anchor spring to the and the top of the brake shoe on an angle first then levering it into the secure position. I needed to hold that spring in place with a screwdriver. Did not need pliers for the spring doing it this way. Hope this part makes sense.
Time to finesse the front shoe hold down spring into position. This one is much easier. Remember to use rwo long thin screw drivers and a pair of need nose splierrs here.
I reused theadjuster because the slots in the old ones were much deeper and less prone to falling out when installing.
Just make sure you clean it well and regrease it.
Throw that tension spring in at the bottom. Very light hi temp grease on those metal on metal wear areas.
Get that tension correct after you put the rotor back on and you are finished.
I had a friend who bought a van that a couple had been living in - got it for a song, but it was soooo ripe!
After going through pretty much what you have, they had another friend who has been reworking RV trailers. He told them he got a small bottle of ozone from AirGas and simply put a hose in one window, with rags stuffed in the rest of the opening. Then crack the valve so it leaks, and let the bottle empty overnight.
End-O-Problems with odoriferous unknowns. They did it and were pretty darn happy and impressed.
You might also look up "Ozone Generator" - they really do work....
I know you probably got most of it, but if it comes back to haunt you - ozone is amazing wrt odors!
Discussion Starter #314 (Edited)
Went to engage 4wd and it's not coming on. Here are the deets. I put her in 4Hi but the light does not come on. I drive it around thinking it will engage... but still no change on the dash. Pull over put it in Park and try 2Hi then 4Hi again. Still no luck. I try 4Lo and it clearly works. Drove around for the day in 4Hi and the dash light never comes on. BUT it feels like I am in 4Hi as the back tires aren't spinning out in the snowy conditions.
Question 1. I think I am actually in 4Hi even though the dash lights do not come on. Is that possible? That the sensor for the front drive shaft is failed.
Question 2. When I put the shifter into the 4Hi position is there anyway that an actuator, or other mechanism fails so as not to engage the 4Hi gears? OR is it as simple as the gear position is in 4Hi so those gears have to be engaged.
Lastly, Question 3. Is it possible that a failing actuator got me into 4Hi and now is permanently stuck in 4Hi? Is there a safe foolproof way to tell that I am in 4Hi or 2Hi.
