TURN SIGNAL REMOVAL: Inst. w/ pics
15056 Views 1 Reply 2 Participants Last post by  OregonSpeedFreak
4
To read the original full thread and post questions/comments on this topic, please go to http://www.fjcruiserforums.com/forums/interior-exterior-visual-tech/62151-removing-turn-signals.html
The signal light housing is attached to the headlight assembly. You have to remove 3 nuts by using a small rachet, 8mm deep socket. Use a medium size flat screw driver and pop out a black clip, then slide/pull out the signal light housing.
Picture of the head light assembly and the signal light housing (together).
Status
Not open for further replies.
1 - 2 of 2 Posts
6
Re: removing turn signals...
More options
Rmove reservoir
one method..works well 8 to 1 black to clear ratio
unlighted
Tight as hell, use ratchet
there are 3 nuts to remove on each light, do not drop the nuts
Good Luck
1 - 2 of 2 Posts
Status
