I would like to install some lights under the dash that would come on and go off like the dome light. Any ideas of how I can wire it up?
i like the mod you have done i looked at them at Auto ZOne i did not find any in Yellow.. good looking imoI installed red and white LED's which I followed a thread on here...I have the red on with the parking lights,you can not see in the pic. but I also have 3 in the foot wells as well..and in the console
the second pic is what I have are the white that are switched. (the fuzzy yellow light to the left) I also have some in the foolwells. Ive got more pics,but like I said its already on here with step by step,just gotta find it...
I bought all what I need for the LED's at radio shack,there is drilling and you use holders,but I also glued mine in. The first couple were tedious but after that it was kinda fun,in fact it was hard to stop from putting lights alover. I will see if I can find the thread that has the step by step to install these.Those Led Lights seem to work well,Im use to using Street glow tubes. How do you mount Leds Do you drill a hole and glue them into it? They seem to be more tidious to install than tubes?
Im looking to do this next.
If you can help me,I need to know if you pry out the pannel that holds the switches on the console area?
I want to remove the entire switch plate to rearange he switches?
You said you wanted more light at night when getting in? I would recommend bright LED dome lights. I have em' in my rig and the difference from stock is well, night to day.I just thought it was a bit dark when getting in at night and wanted to have the light come on with the dome light. The wiring is all so protected and sealed in, I thought someone might have some insight as to an easy way of identifying which wires to use.
dan
pull the cover off the fuse panel (interior) the open slot that works with the parking light is the 4th one from the bottom right. Just use an add a circut, if you need a pic I can get you one.NSB can I ask you where did you tap off from for your lights to work with the parking lights? When I had my heater control apart I wanted to put blue LeDs in the knob lights.
But I didnt have the time to look for a source for the parking lites. Nnext time I my change all the dash colors by over powering the stock lights with super brites The only problem would be to get them to work with the dimmer.Now that bumper to bumper warrenty is up I guess the dealer wouldnt care? My dealer is not mod freindly.
