1 - 5 of 5 Posts
Hi Fellas.
My FJ is understeering big time at the round abouts in wet and loses traction.
I have TJM shocks and BF goodies.
I've done the wheel alignment and tyre pressure is on 30 in 4 corners.
Can anybody help me to see if this is normal or something is broken馃槶馃槶
Seems like your tire pressure is a little low.
How fast are you going in the turns?
You provided very little actual info about the conditions during which you experience understeer, but assuming that if its a manual trans you don鈥檛 have the center diff locked, and if it鈥檚 an auto, you don鈥檛 have it in 4WD.
MOAB SUPERSTAR
Welcome! Agree on pressure as a start - try going up to, say, at least 35psi. Another culprit could be alignment? If you do get an alignment, make sure to check tie rods as they can cause steering issues. Let us know what happens!
Will do. Thanks for the advice
1 - 5 of 5 Posts
