1 - 2 of 2 Posts
I've read all the threads about upgrading interior dome lights to brighter one's. I went to purchase some and the guy told me that upgrading them might produce too much heat..therefore causing an issue. Anyone know if this is true? If you upgreaded yours, what model/type did you use? Thanks in advnace. :ninja:
PIAA, and yes, they get very hot. It is not really a problem though because the metal surface above the dome light is ventilated and then you have nothing but a metal roof above.
If you are worried about the heat, get an LED cluster dome light. It won't be as bright as the PIAAs, but the light will be WHITER than stock.
1 - 2 of 2 Posts
