1 - 3 of 3 Posts
Stahl brand utility bed. Previously mounted on a short bed Chevy full size pickup. Had plans to make an adventure trailer with roof top tent, but ended up finding a good deal on an off road tent trailer instead.
Unit has ports on both sides for dual fuel tank set up which could be handy for installation of aux fuel or water tanks. There are three compartments on each side, lockable and yes I have keys. The compartments are in excellent condition. One of the doors will need a little TLC/adjustment to close tightly. The bed floor is steel diamond plate, appears to be 3/16. Has rust and needs replacement. One of the cross members should be replaced as well. Easy fix if you're handy. I've already cut several welds when I started working on it. When finished, this would be nice to put an axle under it to match the lug pattern on your rig and have lockable, watertight storage for your gear.
$225.00. Advertised locally here in the Redding (Shasta County) area.
Have access to a tractor with forks to load. Delivery possible/negotiable as I go to Sacto on occasion.
Contact me via PM or at [email protected] for questions.
Ron
Gone
1 - 3 of 3 Posts
