The semi-translucent white-ish ones?How about the clips that hold the front grille on?
I can't find the number of the part that "receives" the smaller square clip. It is attached to the fender but one of the "prongs" is broken. Anyone had to order one of those?COWL Panel, each side;
1 x 61991-35010
1 x 61992-35010
2 x 61118-35010
According to https://parts.toyota.com/p/Toyota_2011_FJ-Cruiser/GROMMET---SCREW/69375492/90189A0002.htmlI'm getting a lot of squeak from the screw grommet that holds the door panel to the actual door - the one behind the interior handle.
Does anyone know if the screw grommet (part 90189-A0002) mentioned earlier in the thread will work as a replacement?
I inquired about that part number at the dealership and they couldn't find anything.
Interesting. When I search that part number it does come up on a couple of sites as fitting.According to https://parts.toyota.com/p/Toyota_2011_FJ-Cruiser/GROMMET---SCREW/69375492/90189A0002.html
this part doesn't fit on an FJ Cruiser.
Note, when I read your post, the part number was a link. All I did was click the link to get the answer above.
The site I looked at had me enter a model year for my FJ. I suppose it's possible that it might fit YOUR FJ. Good luck on your search.Interesting. When I search that part number it does come up on a couple of sites as fitting.
But in the process of searching for that part, I also found part 90189-06018, which appears to be the door handle grommet. We shall see...
