1 - 20 of 49 Posts
Voodoo Rider...(new video!)
Present : V o o d o o R i d e r
Stock :
Now :
Body :
-Bushwacker Fender Flares
-4Runner Body Lift Kit(1.25 ») from 4crawler
4Crawler Offroad - Custom Body Lift Kits
Engine :
-Double Yellow Optima batteries w/ selenoid
-Exhaust Flow Master
-Safari snorkel
Light :
-Fog Hella amber 500
-N-FAB light bar w/ 5x fog100w
Suspension :
-OME Medium load front/rear
-Toytec spacer in front
Protection :
-Bud Build skid plates w/cross member
- All Pro rock slider w/ Aluminium checker plate (1/16 »)
Front :
-Lucrum winch mount w/d-ring
-MilesMaker SE9500 w/synthetic winch line
(winch remote control inside the truck)
Wheell :
5x Allied Beadlock Rock-A-Thon Rock 8 chrom
5x Mickey Thompson Baja MTZ radial 315/70R17
4x custom aluminium spacer w/center hub
*this setup of wheel need to change wheel stud for IS300(competition) wheel stud…they are longer and they are perfectly fit!
Recovery Tools :
-High lift on custom roof clamp
-shovel & axe on custom roof clamp
-sling (2x16’) (2x 6’)
-snatch block
-hitch hook
Inside the FJ :
-CB Cobra 75wx st + Bandi mount
-Air tank The Source (15 lbs)
-Rear storage solution w/ 2 big box (thanks to Rick Rock)
Traveling :
-GPS Garmin Mobile w/ Palm Treo
-Sporttrac Bag 21 cub feet (for the roof)
-Hitch platform
The Familly :
Thanks for all of you, for your idea, your clear explanation and your good work.
If you have some commentary, it will be a pleasure to read...I will do my best to answer you but i'm a french person and my english is not very good.
Full JAM
FullJam, very nice work there! Nice custom touches too. :)
pressed send too quick , Did you add the aluminum plate to the all pro rails? looks good, ive been thinking about doing the same thing
Yes, 1/16" thick aluminium checker plate fixed with rivets. The only thing is, the paint is always get off...dont stick correctely! It's been tree time that i paint it since Chrismas vacation.
But for kid is just perfect!
X2 on the N-Fab Light Bar and the Fender Flares!
Very nice rig! :rocker:
1 - 20 of 49 Posts
