1 - 5 of 5 Posts
So after a hard day of wheel'n, my vsc light and vsc trac light will not go off.
I had an insident where I slid into a burm and really messed up the alignment on the driver front. The rear cam on the lower a arm was pushed all the way back. After a feild repair to get the truck the track kinda straight, the vsc lighs won't turn off.
I think its the abs sensor. It was very muddy out there. Any ideas on how to trouble shoot?
Thanks!
John
Discussion Starter · #2 ·
Just an update:
Both the VSC Trac and VSC off light is on.
I am going to look at the truck tonight and clean things up so see if there is lose conection or something?
Any thoughts?
John
First off, you need to go get it aligned. That will let you know if anything is bent. Then dis-connect your battery for ten min or so and this will clear the lights. If the lights come back on then I would start to look at the wheel sensors. Good luck!
X2 on the allignment, if the steering wheel is too off center all those lights will pop
Ok, I had made a similar post... check engine light, and all Vsc lights on... What I found was that a mouse had got under the hood, and under the plastic engne cover, and made a nest. I found this out by hooking up my code reader, and it pulled up a code, P0020. that is a cam position sensor, so i looked at the sensor, by removing the engine cover, only to find a mouse nest, and a chewed threw wire to that sensor, a little soldering and some electrical tape, and it is all fixed.
1 - 5 of 5 Posts
