Ok here I go my so called AAR for this rack though I have yet to see in person.
The Good:
Bigger Tubes, Mesh Flooring, Good bends
The Bad:
Mounting system, Not Wide Enough, Does not follow front roof lines (unused space)
How To Improve: Better Mounting system like ARB style, Widen that sucker out to the edges of the roof (think Safety Devices Safari Rack here), Lengthen front and follow front roof line above trim at windshield, Allow holes in mesh flooring at strategic points for mounting hardware, extend mesh flooring all the way back and to the front more, Cross bar in front before front light tabs to keep cargo from destroying lights, Tabs up front for limb risers, some sort of air damn from roof to rack, light mounts up front staggered middle two tabs an inch higher than the outer tabs up front, composite flooring add on for the future upgrades, Possibility of extra tubes coming down off of rack following roofline to protect roof from stray branches while wheeling, tabs in the rear instead of current light system to mount work lamps. removable cross bars to help secure pelican or hardigg type cases.
This would be a dream rack for me. Just now to find someone to build what I see in my head.
