1 - 20 of 29 Posts
Here is the tag and color list
Add the following tags to either side of your text with the color name of your choice, and Voilà
[COLOR=COLOR NAME] Your Colorful Text Here [/COLOR]
notes:
The tags and color names are case insensitive.
Color doesn't seem to be supported in signatures.
1116858
Discussion Starter #10
It's interesting that the commands are supported but not exposed in the posting options, but Hey! as long as it works.
I wish I could figure out how to set color in the sig.
If you notice, sigs that had it set before the conversion still have it, however, once you edit your new sig it disappears (or at least mine did).
Discussion Starter #11
Reactions: debFJVT
Use the same brackets as @Uncharted 's first post [xxx]text[/xxx]
S = strikethrough Now is the tome time for all men to come aid of their country.
SIZE = font size This is 20 ie 10, 12, 20 etc..
LEFT CENTER RIGHT for justification
This is centered​
Reactions: Uncharted
Discussion Starter #13
FJ Jeep FJ
This is fun
Reactions: Lee44
You can combine them. Be sure they are correct when you Preview them. Can't edit the code after you save it.
WHOA!
Desert Moderator
They don't always show up as well in dark mode...
Desert Moderator
It's the blues that don't work well
I noticed. That one is tough to see and its not edited, its the forum normal blue.
Did you notice that @Uncharted 's bouncing blue blob is animated? But not Baz's. The guys must be working on it. Mine worked for a while but not now.
Discussion Starter #19
  1. Voodoo Blue
  2. Army Green
  3. Sandstorm
Reactions: Lee44
Discussion Starter #20
Or
  • Voodoo Blue
  • Army Green
  • Sandstorm
Reactions: Lee44
1 - 20 of 29 Posts
