So, I was mudding the other day and the check engine, and all VSC lights came on while I was driving. I took it to Autozone to get the error codes which all had to do with the emissions evap system.
PO43E
P2401
P2402
P2419
After looking on the forum I had a few options to check.
I cleaned the MAF sensor, check gas cap, check wheel speed sensors, etc... nothing worked.
I had Kwik Kar diagnose it while I was getting my oil changed and they finally figured out that the pressure sensor or evap valve is apparently in a bad location for mudding and can get clogged very easy. They said these are usually behind a fender or something to keep them from getting mud on them. If these lights ever come on for you this should be something to check.
Hope this helps someone!
PO43E
P2401
P2402
P2419
