3061 - 3080 of 3084 Posts
2013 FJ OD Manual
Bought 8-10 hours of shop time to install: Rigid Backup Sensor, LED flush mount backup lights & harness wired to OEM rocker to complete the ADD rear bumper, Rigid D Series SAE LED Fog Lights & OEM rocker to complete the N-Fab front end, QualCom USB rocker, OEM AudioPlus FJ Cruiser Sub woofer, speaker & amp upgrade and wire (2) OEM 12v cigarette adapters, one at center console (passive) & one at rear cargo area (active), and install my SmartTap as I'm too old and not flexible enough to do this anymore. Date August 6 & 7th, I'll have pic's to post in a couple of weeks.
I'm in my youth and that flasher was a pita to get to. After I finally got it hooked up I zip tied it to something wasn't spending anymore time in that position. The tap turn lane change made it all worth while though.
Reactions: Lee44
Head gasket(s)? What did I miss?
Also, what is item #3?
1. Chinesium electronic __ gauge.
2. Iridium Super Tough VKH22 plugs not available stateside per se
3. Aluminum coolant expansion tank to replace a plastic coolant expansion but needs a cap.
I have more to show when I actually get something done :confused:
Well...I figured I should purchase some ditch lights...why not? So here is the setup:
1. DB Customz Cowl Light Brackets
2. Baja Designs Squadron R Sport Driving/Combo Pair
3. Replacement clips for those pesky cowls
Plan is to wire it up to my sPod. At some point, I'll do a dual battery setup...just not yet...
2008 FJ, 3" lift, american racing rims, homemade t-case shift handle
How are you liking it so far? Been toying with the idea of getting one.
Pics of expansion tank please
Not using it to replace my stock coolant tank. On supercharger kits, we have a plastic tank that runs in and out for a cooler. This aluminum tank will replace the plastic one that is prone for leaks.
Couldn't find a good 1" wheel spacer kit that included extended thread lug nuts. They have lug nuts available, longer than 25mm/1". Much more threads but needed to be shaved down a couple mm.
