3081 - 3100 of 3137 Posts
So ChiTown4x4 finally got their fuel carriers back in stock! Woohoo! Yep, I'm out more money, but this one is definitely worth it!
@Itsnotme What are those? Kind of interesting.
Rotopax Bar Mounts
Some nuts, and bolts, and stuff...
1136997
-Massive Denso filter 150-2066 (optional V6 cross reference for Toyota's YZZD3 oil filter). Not sure it fits without supercharger interference.
-Greddy sandwich adapter for sensor ports. I should be able to get an oil pressure and temp gauge that I wanted. **and not sure if makes any difference but I assume this billet piece may pull some temp from heat exchange naturally. Not a biggie but I don't want to run anymore coolers if I can avoid it with a trans cooler and supercharger intercooler in the way. Greddy also makes a cool thermostatic adapter to run with an external cooler! (4th pic)
Borrowed pic from Torspd (tacomaworld) with adapters to port an external cooler if needed
I went online to see what an engine air filter costs and what options there are.
NAPA. Has a sale today and tomorrow, 25% off when ordered online. So I ordered a NAPA gold filter and will pick it up in a bit.
I was thinking of the Wix filter, but they were the same price before the discount. So $6 off.
Look good. Are these for sleeping in the FJ?
That and just general air flow. Visibility is surprisingly good, but I think I will save them for the times I'm off the highway.
MOAB SUPERSTAR
Love my discos 👍 Have you used yours yet? Make sure the lower bolt is tight because if it comes loose the swaybar will drop down and slice open a cv boot - I lost 3 boots that way! As a result I now make a habit of checking - frequently. I also swap back to OE links for winter as the salt has destroyed many sets of heim joints.
Haven't used em yet, currently on my way to Eureka Ca. with hopes of finding a place to test them out. Used two jamnuts on the bottom and some orange locktite for peace of mind. I still check them every time I stop.
Reactions: debFJVT
A lug 6 spline lug key that I never with the truck and lug nuts for the spare wheel that just arrived yesterday. Yes, my truck is that incomplete.... Is there supposed to be a dome light in the truck? Sure is dark in there. I think my new bottle jack arrives tomorrow.
トヨタ Master
トヨタ Master
I was worried about that too, so I added bump stops. No problems so far.
Are those accessory clamps? Thinking that if mounted above the rear door at a steep enough angle, with a 4 gallon Rotopax, that it will act as a dust deflector and keep the back window clean. Hmm...
