07 AT, 4WD, Toytec 3" Lift, SPC UCA's, Nitro 4:56 , ARB Front/Rear, Full Rack, 285/75/R18 NRG,
I think I saw the gas gauge move down a little 😁2nd gear pull. Still a bit nervous to push my luck
Wheel bearings?Ok - so while I have this in the shop , front end will be torn down completely. I'm adding a Toytec 3" ultimate lift with SCA upper control arms. Truck has 137K . What other parts should I look at replacing while it's apart? Had new OEM front axles installed 2/20 . Thanks in advance
I have used a product called REJEX for 20 years on all of my windows, It does not leave a film. You can use it on anything that is non porous, I use it on my headlights, turn signals, brake lights, side mirror covers, trim around the windows and many other places. Do a test area if you are unsure. I use it as my primary wax for everything, great stuff!Gave her a bath. Temps are good enough that I could do that. However the high pressure spray peeled a piece of rubber weather stripping off of the suicide door. I glued that back on. Also applied RainX to the passenger side of the windshield. The last time I used RainX the windshield was really streaked. I think it was the warm weather. Cloudy and 50 degrees outside now. I hope to have better luck.
That's decent output for amber lights. Which brand did you use?View attachment 1153500
Wired in some amber rock lights
Wheel bearings?
Thanks - I will add them to the list.
Brought it to Jungle............of Manhattan
The URBAN Jungle, at least you parked next to a tree!
View attachment 1153687 View attachment 1153690 View attachment 1153688
