1 - 6 of 6 Posts
Just as the title says, what kind of hardware do i need to mount the OEM TT rock sliders on my FJ? if you could tell me length and grade that would be solid! thanks guys!!
M8-1.25 flanged type bolts, 30 or 35mm long, grade 10.9
You need 16 pcs of this bolt and flat washers.
flanged with big ole washer. If you PM me I can send you a pic of the bolt with the washer attached so you can get an idea of the size of it.
30 mm will not work. has to be 35 mm
1 - 6 of 6 Posts
