1 - 9 of 9 Posts
Hi all!
I just got my 2012 FJC Base 4WD less than a month ago. I looked at the engine bay when I was inspecting it prior to buying and found this (see pictures). Didn't know what it was, salesperson didn't either. I said well, it drives great so WTH! The orange air hose leads to a fitting that is not attached to anything. Could the previous owner used this as onboard air? Help a newbie out! Thanks in advance!
Moto ServDog
It is exactly what it says it is - ARB Air Locker. That is the controller. You need to look at your differential and see if you have that pieces as well, or if whoever put it in took it out and just left the controller.
Google it amigo...
MOAB SUPERSTAR
If you have a front locker switch 1) congrats! 2) do not engage unless you are going Lo and Slo! What gear ratio do you you have - 4.56? If you do not know please try to get the info - it’ll be important going forward. Feel free to ask any and all newbie questions about this - we will be more than happy to answer anything :wink Sounds like an excellent FJ and interested in know what else you have on it!
トヨタ Master
Does the stainless braided hose coming out of the compressor hook into the orange hose? Hard to tell from the pics. If so, you simply have on board air. If the braided line snakes it's way down to your front axle/differential area, you have a front locker as well.
Reactions: jcfj10
The orange hose terminates with a quick connect fitting like standard air hoses. I am thinking that the orange hose was used to inflate tires on the trail. Plug in an air hose with a tire chuck and fill the tires.
But yes, do look for any extra fittings on the diff. And see where the braided hose goes.
ya, not sure but i will give you $10 for it prob just extra weight.... No,, either air lockers if you have lines going to diffs or on board air pump....
1 - 9 of 9 Posts
