1 - 6 of 6 Posts
The only thing I would change is use body clips that are removable when installing the new splash guards. You know, those ones that have a screw in center pin that can be backed out? Those solid push in ones are a PITA to remove and I usually remove the guards to do coolant changes or get at certain bolts when doing maintenance.
1 - 6 of 6 Posts
