61 - 73 of 73 Posts
トヨタ Master
Which tire? How much lift? BMC?
I've got a stock TRD with a 1" front level and 16's and I was wondering if the 285/75/16 trail grapplers would rub without a BMC...
It's all about offset and width. The wider the wheel, the closer the tire comes to the body mount. They should fit on stock wheels without rubbing.
Just got some new Ridge Grapplers, 285/75r17:rocker: Don't know how i feel about the slightly narrower width, but the overall height of the tire looks good.
Do you have a BMC? Trying to determine what I can fiasco if I went to this size with a 2 inch lift and adjustable SPC UCA.
I have the Icon 3"+- set up with UCAs (stage 2), and I do have the BMC. I do not know if they would fit without the BMC, but I am also running 1.25" spidertrax as well. With a clean BMC, I don't feel like there is any negative reasons not to do it, but i do understand why some are against it.
I also have the 285-75 . in the stt pro . 3 inch lift 1.25 spidertrax stock wheels . They work Great . But i am Kicking myself for not going with a wider tire . Easy fix though .
No fiasco, you will most likely need a body mount chop. I have this same tire and size. Fox's are set at about 2 in of lift and I had SPC UCA and now Total Chaos. No issues with either UCA. Get the alignment guy to get your caster closer to 4.
Someone say tires...39.5/12.5/16.5 on military Humvee double bead locks
Looks like someone stole your wheel locks FJ4 lol
nah, they were in my pocket. The picture was a work in progress. wish the tires looked that good now, they are expensive.
Anyone running method 105 ?
17x9”
Offser : -38mm
Backspace 3.5 “
Will fit without rubbing??
Enviado desde mi iPhone utilizando Tapatalk Pro
You might want to try a 2" leveling/lift before going for a BMC.
Thank you I haven't done the chop yet - She's getting a 3" next week and then we'll see. I want to go to 35's next year think and leave it there. :laugh
61 - 73 of 73 Posts
