1 - 14 of 14 Posts
Hi All--
So stoked to buy the New Trail Edition.
Got the roof rack to cary surfboards. Was told by the dealer that the bars were exchangeable. i.e bottom rail to top etc...
Well get the truck home grab the boards and guess what they are not interchangeable at all. Plus what's up with the plastic ends??
Question:
Why only one long rail and again why only one? What can you do with just one? (Dry a towel)
Called the dealership and there response was well we don't sell them separately.
Lovely 800$ for some thing that is utterly useless and cuts MPG's too..
Anyone know or have any luck securing another top rail. I don't want to go spend another few hundred to make something i have already purchased work :boohoo:
Please if you know something please help. Thanks in advance
I took one of the screws out of mine once, which allows it to extend a little further and moved it almost all the way to the front. Not sure how much weight I would put on it after that but you could give it a try.
What about something like this?
Costco - Inno Boardlocker Surfboard Rack
$149.99
You can put in a WTB ad in the sale/buy section. I've seen people selling stock racks. They may be willing to part... you never know.
The ends are held in place by torx screws. You can loosen those and then extend or contract where the ends attach to the cross bar.
How in the world did you have to pay 800 for the roof rack?????
That is absurd.
The bars are adjustable at the ends, you just have to fiddle with them to make them fit. :D
Mine don't even come close to fitting when I try to slide it forward. Yes, one side does have a sliding section and I can move it in/out. But there's just not enoug play to get things wide enough.
I can only slide it as far fwd as where the doors meet. Was hoping to get it fwd to haul the 12' kayak.
Mine works...I'll try to find a pic with my kayak on the OEM roof rack for ya!
Tim
Tim
Hmm. I even tried to loosen the front mounting points of the rack to see if I could move the front side inward. But they wouldn't move nearly enough. At the front of the rack, it's prob. 3" too wide for the front rail...even with it spread out as far as it'll go.
Only one side moves for expansion. Right?
I don't have my FJ with me today. I will look to see what I did when I get home this evening and take some pics for you. I have an '08, so I assume the roof rack is the same as previous model years??? If I remember correctly I was able to slide it quite a ways up toward the front and both ends were expandable.
Tim
Okay I just went out to give it a deeper look.
The cross-member on the top was shorter than the ones on the bottom. So I took one from the bottom and put it up top, expanded all the way out and with it all the way forward it comes very close to fitting. Not quite, but close enough to tighten things down. But now I cannot get the original top cross-member to fit on the bottom. So I'll get out a tap and dye set. There's plenty of room to add an additional screw hole on the underside of the the cross-member(s) which will allow me to connect the clamps and give me enough play-room.
Things should have been this way to begin with but I guess since it's a dealer (or port) add-on they just slap them up there without much thought or consideration.
Question. Does the top cross-member scootched (nice word) all the way forward cause a lot of wind-noise? Or am I going to have to move it back and out of the way each time I'm done with it?
They do in fact ship with three and one.. I can't remember which number below is long/short, but the info is on here somewhere. I believe MSRP on the option/add-on is about that.. Ron
Roof rack bars
PT278-35060-CB
PT278-35061-CB
Hi All--
Question:
You can move the bottom crossbars to within a foot of the front of the rack. Use one of the bottom bars which are longer. I used the OEM crossbars to carry 4 boards all over Baja, no worries. A better set up is an aftermarket rack like Gobi, ARB, Wilderness Trails, etc. You can also use the Yakima crossbars on top of the existing rack or with the stealth mounts that someone here on the forum (Fjoel) produces. The OEM's do work though.
This picture shows the crossbar forward and holding a 6'8" fish. I never had to adjust anything and I was pretty tough on the rig this day.
You figured it out. :) I don't remember much noise until I added lights, then forget about it. :lol:
I used these Thules for up to 3 short boards or 2 longboards. $60.00 and super easy to use. They fit the OEM crossbars.
Here is a picture of a set up 60" Yakima cross bars U-bolted to the aluminum OEM rack. This is a rock solid setup.
1 - 14 of 14 Posts
