1 - 4 of 4 Posts
When my headlights are on i have no Brakes lights or turn signals?
Just put in New LED tailights and when i switch my headlights on the taillights don't work anymore?
2007 Toyota FJ Cruiser
3" Rough Country Lift
33" Mickey Thompson Baja MTZ Tires
APC Turn Signals
Spyder LED Tail Lights
Steelcraft Brush Guard
Body Armor Tail Light Guards
welcome.
Which LED's did you use.
That is really odd. Did you just replaced the tail light bulbs or the entire assembly?
If just bulbs, sounds like they are designed for dual tail light and brake functionality or the connector isn't seated.
If it was the entire assembly, connection issue, need a little more info to help.
Discussion Starter #4 (Edited)
Black Spyder LED taillights
Spyder® ALT-CL-TFJ07-LED-BK - Toyota FJ Cruiser 2007-2011 Black LED Tail Lights
It a whole new tail light unit. You replace the Taillight and Turn Signal with a LED plug that connects to existing bulb connectors. The Reverse bulb stays the same.
I can start my FJ and Turn on and off the headlights and tail lights will do the exact opposite. I checked all the fuses and connectors to make sure that they were plugged in correctly. Confused....
1 - 4 of 4 Posts
