1 - 4 of 4 Posts
I bought this 07 FJ 2 years ago, one of the previous owners installed this aftermarket “A” arm. There is a model number and patent number, but I dont see a brand. Can anyone identify this so i can buy parts and service it correctly?
1119023
1119024
fka BLACK HAWK
best is subjective... Uniball and ball joint styles both have their pros and cons. I personally went with the Camburg ball joint uca. it uses a MOOG available at any auto parts store for easy replaced if need be while on the trail. Uniballs offer more articulation but require more maintenance do to exposure to the elements
2007 Toyota FJ Cruiser
I have just replace the uppers and lower controls arms on my 07 fj with oem parts and upper control arms have a A mark.Posible you have oem .If you plan to change arms by yourself make sure you order cams ,bolts and nuts because maybe need to cut the older rusted to take the lower arms. Used a 700ft impact and not able to turn bolts around in bushings.Finally cut bolts and bushings on lower control arms.
Learn my lessons and when with OEM not taking chance with aftermarket parts.
1 - 4 of 4 Posts
