21 - 29 of 29 Posts
Similar question, but perhaps OT: If I just want the vent on, I found that the AC kicks on if I change the temp dial to its coldest. I press the AC button but it won't turn off. Any tricks for this?
Don't turn it to the last position. If you look closely, you'll see it turns Max A/C on when you put it in the final cold position. If you adjust one position clockwise, A/C shuts off and you're good to go.
Turn the temp dial one notch above the coldest and hit the A/C button.
Just back off max cold one click.
IIRC, every car I've owned (from an 87' mitsubishi truck) to this 2010 FJ has always had a little airflow from the ventilation system even when everything is off.
Not that big o' deal. Adjust the temp or something.
My recirculate wouldn't shut off with the front defrost on. As long as I was on front defrost or front defrost/feet the recirculate came on!! Would not come off
Any suggestions?
i know this is flame free forum, but geez guys my Fj came with a owners manual. As for air flow, all cars do thart since the 80's
not sure if its been answered before, but, there will always be a little airflow, on each side of the vehicle to reduce the change of fog on the windows.
21 - 29 of 29 Posts
