1 - 6 of 6 Posts
Hello, I have a question.. My FJ has a OME 4 in lift. I currently have the Pro Comp X Terrain 33's all around, including spare on 17's. I want to go 35's. Is this possible without affecting the lift?
35" tires will fit with the OMEs, but it will require a body mount chop as well as some fender well trimmings.
Also you won't be able to run the factory wheels with the 35s unless you get a wheel spacer or a after market wheel with a small enough back spacing. Otherwise if you don't get spacer for the factory wheels, the tires will rub against the UCAs.:cool:
ya i also want to know when ome makes a 4 inch lift but oh well maybe a typo
You'll have rubbing issues with 35's at full lock even if you chop the body mounts if they're 12" wide tires.
I'd stick with the 33's if I were you. You can run the 33's without a spacer and without RE-GEARING your FJ. If you want to run 35's you need to seriously consider re-gearing the rig and lowering the ratio. That means more power, but the mileage will suffer (more). If I was to re-gear, I'd put in an ARB air locker at the same time.
Consider the complete impact that 35's have before you leap.:read:
1 - 6 of 6 Posts
