1 - 6 of 6 Posts
Pro Comp Series 97
16x8, 5 on 5.5 Bolt Pattern with 4.25" backspacing on a 255/85/16 BFG M/T KM1 tires and a three in lift? Or is the correct bolt pattern different? If so, what is it?
Second down:
Off Road Truck Series 97 - Black
thanks
Wow. Spaced there for a minute. Thanks. I come from the land of 5 lugs.
From what I've read, the Series 97 will not fit because of how the holes are. They have a lip on the back side from how they are formed and that lip hits the calipers. You could probably use some spacers to get them to work. I have been looking at the Series 87 16x8's. Everything I have seen on the 87's indicates that they do fit without hitting the calipers.
Discussion Starter · #6 · (Edited)
Thanks. Not interested in running a spacer, though. I'll check out the 87's. Not sure what they look like.
Edit: Just checked out those wheels. Those will be mine. Nice!
1 - 6 of 6 Posts
