1 - 8 of 8 Posts
Hey Guys - Need the opinion of all you wheel experts!
Will these wheels fit stock suspension w/o rubbing. I was hoping to go with the largest tires possible, 285/50-22 or 285/45-22.
Please no flames please from all you rock crawlers. I know these would suck off-road but the nearest my FJ gets to off-road is on a gravel driveway!
Thanks in advance for any input.
Diameter and width should be no problem. You'll have to find the right backspacing to make it clear caliper and UCA though. tire size calculator.
could you buy a big enough spacer for that wide a wheel?????? That would end up with some kind of lip with the right back spacing wouldn't it?..... But I suppose if it is only 10 inches wide....Would certainly fill the wheel well fur shur.
I missed the rim specs. NBFJ is right, you should go with a narrower rim. 22X8 should be wide enough.
I just looked up that wheel. It looks like it's for Nissan. Did you verify the centerbore? They only come at 10.6 for 22in. Cool looking wheels, but at ~$500/wheel, they are spendy.
Whoa!!!!! $500 for 1 wheel!!!!:jawdrop:
I can get a whole set of OEM steelies for that price, and still have some $$$ left over.
1 - 8 of 8 Posts
