1 - 4 of 4 Posts
KMC XD Enduro 17x9 0 offset, BFG AT 285/70/17, 3" lift.
Correct me if im wrong, but the black no bead lock Enduro doesnt come in a 10" width?
I have a friend selling me a fairly new set of Enduros and as far as he knows they are a 17X9, im assuming he is mistaken and means 17x9. in anycase, would the above setup cause any issues? will i need hub rings?
Discussion Starter · #2 ·
bump
anyone?
First, you would not want anything wider than a 9" wheel with the 285 tire. My current setup is a 17 x 9 AR Chamber Teflon with 285/70R17 tires. The wheel specs are 4 1/2 bs with -12 offset. This off set pushes them out and made them rub more aggressively on the mounts which have since been cut back. I believe these will work out fine with no rings and give you less rub issues when turning.
1 - 4 of 4 Posts
