1 - 4 of 4 Posts
Can anyone advise on the order or hardware to attach the winch to the bumper. I have bolts, flat washers, spring washers and nuts. The nuts go into the foot of the winch.
Is it 1) bolt, 2) flat washer, 3) spring washer, 4) bumper plate and then 5) nut?
1139234
1139235
Discussion Starter #2
These videos indicate 1) bolt, 2) spring/locking washer, 3) flat washer, 4) bumper plate and then 5) nut as the proper order. That's what I'll do
1139294
Mean Time Moderator
Generally the foot of the winch only has room for the nut. If there is space for a flat washer than I use one. A spring washer should always be first onto the bolt so it sits against the bolt head, then the flat washer (so it is against the hole)
1 - 4 of 4 Posts
