DISCLAIMER: Part numbers, Prices & LINKS to parts do change over time.
Please do your own due diligence and verify.
This is what I have found while researching parts for my 2011 Army Green/NSSE, color code 6V7.
The reveal molding retainers to upper body/frame are screw in replaceable, 4 each.
The upper molding is reusable if a qualified/competent installer is doing the work and removes it without destroying it.
Toyota 75503-35060-AO = White
Toyota 75503-35120 = Army Green/6V7
***The windshield "tech" where I went was wrong when he said that AG was not available, white would have to ordered and sent to a body shop to be color matched. Guesstimate was $300-$500 and maybe 2 weeks turnaround time.
Pure FJ Cruiser REVEAL MOLDING RETAINER [75563-35010] - Reveal Molding Retainer. See number 11 in the diagram. The FJ cruiser molding requires FOUR of these to reinstall the windshield molding. Adjust quantity accordingly.
www.purefjcruiser.com
Pure FJ Cruiser Toyota Reveal Molding Screws [90159-40183] - Also referred to as a Screw W Washer Tap. This too is a genuine Toyota product fitting all models of the FJ Cruiser.
The 4 each side corner cowl panel clips
do need to be replaced each time. FJC forum Supporting Vendor PUREFJ sells them as a set (per side) ready to go.
Pure FJ Cruiser Au-ve-co FJ Cruiser Cowl Clip Set [FJ-COWL-CLIPS] - Toyota FJ Cruiser cowl clip set. ONE set. If you need to do both sides of your FJ, then choose a quantity of two. Free First Class Shipping! Kit includes: 2 x 61118-35010 1 x 61992-35010 1 x 61991-35010
Pure FJ Cruiser Cowl Panel Pad [75537-35010] - This is the little rubber trim that fills the gap on the cowl panels. See #10 in the diagram.
If the "A" pillars needs new clips, 5 each side...
Pure FJ Cruiser A-Pillar Retainer Clips (10 count) [75392-35210x10] - This is the (single use) retainer clip (75392-35210) that holds the A-Pillar covers onto your FJ Cruiser 07-14. This includes 10 clips. Enough to do both A-Pillars. Shipping is included.
And have LEFT & RIGHT facing seals underneath the "A" pillars.
75566-35010 Genuine Toyota Protector, Roof Side GARNISH (toyotapartsdeal.com)
75565-35010 Genuine Toyota Protector, Roof Side GARNISH (toyotapartsdeal.com)
If the spot welded on retainer is pulled off, it'll need to be welded back on by a body shop, sealed and painted. You don't want any pin hole leaks.
RED ARROW
