My Yota dealer in Hyannis, sold me just the rubber refills. $7 each.
Thanks, How long ago?My Yota dealer in Hyannis, sold me just the rubber refills. $7 each.
a year???????Thanks, How long ago?
Buy the refills at a Toyota dealer. They are inexpensive this way. Factory Toyota wiper blades are a durable product and only need replacing if they are damaged. Just get the rubber refills when needed. If you do replace the whole blades with something aftermarket, then keep the originals for resale value as original factory blades are a bit expensive and usually have to be ordered in.Where to buy? Need refills, not the entire blades. Or is that the only way they're sold now? My blades have Toyota logo on them. Has anyone replaced just the rubber refills?
ThanksBuy the refills at a Toyota dealer. They are inexpensive this way. Factory Toyota wiper blades are a durable product and only need replacing if they are damaged. Just get the rubber refills when needed. If you do replace the whole blades with something aftermarket, then keep the originals for resale value as original factory blades are a bit expensive and usually have to be ordered in.
For reference:
85212-13031 wiper blade assembly driver side
85214-50061 replacement wiper blade rubber driver side
85212-35091 wiper blade center, passenger side
85214-68011 replacement wiper blade rubber center, passenger side
85242-35040 Blade, Rear Wiper
85214-35070 Rubber only, rear wiper
The "rubber only" replacements are literally just the rubber. You need to transfer the stainless steel strips from the old blade rubbers. It is a little tricky installing the new rubber since you have to keep the stainless metal strips in the rubber groove as you insert the blade but with a little effort they install nicely.
Toyota dealers also stock cheap whole blade replacements that aren't of the quality of the original factory units. The real OEM blades usually need to be ordered in and aren't stocked. Don't be fooled into replacing the blades with plastic junk.
Can you get a pic of your "replacements" so I can compare to mine? I don't know if I have the originals or not 😕Wound up at a Toyota dealer and it was an ordeal. Apparently at some point, my regular dealer changed the blades to a type that has to be changed entirely when the rubber refill is worn. You can't just replace the rubber inserts. The new dealer replaced the blades with a version that is cheaper, but they still have to be dispensed with when the inserts wear out. They told me I should have kept my original equipment, which allowed just the refills to be replaced.
I can provide a picture of my factory original driver's side wiper. The other blades are styled similarly. I've intentionally overexposed the picture to show detail. The blades are all metal, riveted construction, and with the replaceable squeegee. The fatter end of the rubber part on the end is how the rubber blade attaches with the rubber barbs behind the first bracket.Can you get a pic of your "replacements" so I can compare to mine? I don't know if I have the originals or not 😕
I felt a bit silly posting a big diatribe about something trivial like wiper blades above, but this is exactly why. Toyota provided a quality product that allowed for very low maintenance cost, but most people didn't know this and replaced the whole blades anyway. If you want to go back to the OEM solution, the real factory blades can be ordered in and come with a rubber blade installed. They are priced similarly to the higher end aftermarket blades, so after replacing the inserts once, you are probably ahead financially again.They told me I should have kept my original equipment, which allowed just the refills to be replaced.
Here is the link on Amazon.I just bought all 3 refills off Amazon.
