Pin Order
I have a question. Since the FJ already is wired for fog and aux lights, is it possible to use the Toyota wireing? There are places for the fuses and relays already in place. Could you buy the needed connections from Toyota and use those? It just seems a waste not to be able to use existing wireing.
Have you done a writeup? Please post a link if you have. If not, how about a list of parts number.__________________It can be done with the factory harnesses.
Which is to say, OEM switch, OEM switch harness, Toyota relay, 15 amp fuse, and the OEM lamp harness, using my PIAA 520s.
Yes. I believe so.http://www.fjcruiserforums.com/foru...-free-freight-untill-05-31-07-pt278-35071.pdf This pdf is for the install of the factory roof lights.I drilled and installed some 510's on my rack this weekend. While running the wiring I saw a harness insidde the A-pillar about 1/2 way up. Is it the other side of the wiring harness already pre wired for lights up top? K
Parts List:Have you done a writeup? Please post a link if you have. If not, how about a list of parts number.
The switch does not have a relay built in and you should never use lights without a relay. You will either have to use the relay supplied with your aftermarket kit or do as colink did and use get the Toyota one and related fuses etc. I chose not to use the harness in the A pillar since I did the no drill method and end up with all wiring in the engine bay and I didnt feel like running all the wires back into the cab and then either buying the headliner harness and splicing into it or cutting off the connector and splicing into the wires there. If you drill through your roof, then colink's approach may indeed be easier, but you will need to get more parts than I had ready access to.so that switch has a built in relay i take it. weird that they didnt use 86-85-30-87a-87 for labeling.
I didnt go your route, but I do have a questions since I did think seriously about going your way.Parts List:
(1) Fog Light Switch PN: PT297-35070-SW
(1) Switch Harnes PN: PT297-35070-SH
(1) Lamp Harness PN: PT297-35070-LH
(1) AUX relay PN: PT297-89016
(1) 15 amp fuse
The Toyota aux lighting instructions references these wires and states to tap them, but does not indicate which one is which. I believe one is the ground.I think I tapped the green and green/white wires to get power for the backlight and powered lighting. I can't remember the order.
Ok,The Toyota aux lighting instructions references these wires and states to tap them, but does not indicate which one is which. I believe one is the ground.
Green - backlight powerOk,
Has anyone confirmed the green and green/white wires for this center console OEM fog light switch install?
