I bought 3 sets of hellas(2 lights per set, comes with a relay per set also)
and i have the warrior products light bar (holds 5 lights)
Wired the outside 2 lights to one relay and the middle 3 to another relay.
Things didnt work after my first attempt so i redid all my ground and double checked my wires on both relays.
Got the one relay with the outside 2 lights to work. Could not get the middle 3, but i know i did everything right.
Both relays made a clicking noise when switched on so i know they draw power, but no power is reaching the middle 3 lights, but i know everything is grounded properly (to test i ran a direct negative line off the battery to each light and still no power to the lights)
then the other day when i went to test the lights one more time, the relays vibrated and then there was no power to either lights. no fuses were blown
What happened?
What happened?
