Is that how you have to do it in the 2wd Kim?You put the rig in low to engage the diff lock, right? I know that is a pretty capable little deal. I have managed to get out of some rather "sticky" situations with that combo.
Kim
I did, last week!!! And it was FUN!!!!!Is that how you have to do it in the 2wd Kim?
Make sure you are going under 5mph and NOT TURNING. Drive straight while engaging.
If you try to engage while turning OR while a wheel is spinning (trying to get unstuck) the locker will try to lock both wheel. This is a problem because one axle shaft is spinning and the other isn't. You will seriously mess up your rear end. Now go get stuck and use that locker to get out Kim.
