1 - 20 of 26 Posts
Lol, good luck! I have already given up and bought new 16" tires
I'm hoping if all else fails I can still purchase them new, but availability may still be difficult from what I hear. Not in a big hurry to get them..... yet. These things are unicorns that's for sure.
I Have a V-8!! Moderator
If they are like the Tundra version, they were discontinued a year or so ago. They were around $3-- something per wheel new and just a couple of days ago I saw an add for a set of four in so so shape for almost $600 per wheel. Crazy expensive now along with being rare.
Yeah I heard they might have been discontinued recently. $310 per wheel is the cheapest I can find new if they are even available. Guess I should confirm new availability with some of the vendors...
My coworker has them on his bone stock 4runner... what a waste right:mecry:?
:mecry:
Toyota of Cool Springs was the cheapest I could find when I was looking at them for the Tundra. I was almost ready to order and the price jumped, dropped a bit, and then jumped again and that's when the discontinued notice came out. The used ones I found were almost the same price as new and some of the wheels were in rough shape. I'm looking at a set of the 16" Icon Six Speeds now.
Discussion Starter · #11 ·
Just, do it! Dont let your dreams be dreams.
Thanks bud, I can always get my money back out (unless I scratch the rock rings up haha) since they probably hold decent value. Just trying to find some used ones first. As you know I like the near factory offset and don't hate the look of the RW's either.
Will you still need to use wheel spacers with these rock warriors?
Discussion Starter · #13 ·
That's another reason why I like them. They stick in quite a bit like stock (+6mm offset) so if/when I go LT it will look more stealth. With measurement help from Kai I think I can get by running 35's without wheel spacers on stock spindles (no gussets). Plus my rear end will be extra wide so I'm fine there.
But you will do spindle gussets with your LT setup right? Not sure it will clear. That’s why I went aftermarket.
2007 FJC 4x4.
I saw this link in one of your posts.
So the 5 lug Tundras are like et60 offset....
TONS OF ROOM....for...adapters!
Why not get adapters to the 5x150 Pattern and just run Tundra wheels? There are SO MANY out there for sale that it seems kind of worth it.
I guess the big hiccup is that the Tundra uses 14mm lugs so they would certainly be pretty custom adapters.....
Discussion Starter · #20 ·
At this point I think I'd rather wait and get the set that is designed for my vehicle. No headaches that way! (and running 5 lug just feels wrong) Plus I'm still not 100% on what backspacing I need with my future setup so I got the 5 Level 8 MK6's for $490 to my door. I'll get them on, finalize my setup and go from there.
1 - 20 of 26 Posts
