Now I do have that, but the question is does it work? I have a string of bad luck with them.If you have a Harbour Freight near you...you can buy a step drill bit and a Hole saw kit for less than twenty bucks.:cheers:
Yep! they work...the situation I had was I tried to use a cordless drill and it was agonizing slow to drill the 105mm hole. Thank gawd I had a exta pack for for my Mikita...Use a plug in drill it has extra tork and the speed rpm's to make it easy. Iv'e done about five installs so far and it's real easy if you take your time.Now I do have that, but the question is does it work? I have a string of bad luck with them.
ah.... easy.... maybe.... but the thought of making that hole.... not looking forward to it.:mecry:Yep! they work...the situation I had was I tried to use a cordless drill and it was agonizing slow to drill the 105mm hole. Thank gawd I had a exta pack for for my Mikita...Use a plug in drill it has extra tork and the speed rpm's to make it easy. Iv'e done about five installs so far and it's real easy if you take your time.
Make sure you use plenty of the blue painters tape...I taped everything where the template will cover and mark the holes...check everything twice and just do it... :lol:ah.... easy.... maybe.... but the thought of making that hole.... not looking forward to it.:mecry:
