Hey everyone. I recently installed some 2.5” halo fog LED lights (30w, real power consumption 10w) off of Amazon in my side view mirrors and wired them to a CH4X4 Aux switch. Now my roof lights will not work! I have 4 Hella 500 h3 12v 55w lamps on a light bar that are wired to another CH4X4 switch. I used 12 gauge wire to ground all 4 lamps and 16 gauge wire for the hot line. I ran one hot wire per 2 lamps to a 30 amp relay with a built in resistor and to the battery. I have the hot wire running from both relays to the battery via an in-line 40A fuse. The ground to the switch/lamps/relays are connected to the frame. Off the switch I have a “add-a-circuit” plugged into the cabin fuse box. I ran the switch light wire to the oem dimmer. This setup has worked for over two years! So the only thing I did to have both switches light up is combine the two switch wires that go to the oem dimmer so they both light up in the cabin. I have checked ALL my grounds and they are good. I’m not blowing any fuses. The halo LED lights work perfectly. I replaced both relays and the roof lights worked but the second I put everything back together and pushed the switch they didn’t frickin’ work again! Ahhhhh!!! What could I be doing wrong?! Someone please help me before I waste anymore time with this.
