My AC always blew cold, then started getting a little warmer and warmer for many months then the light started blinking I tested the relay and it works. It started working again after not working for a couple months but didn't blow super cold, then blinking light again. When turning the AC on you can see the clutch move just a tad and then the light blinks again. I put the gauges on to try and add refrigerant and got the readings in the picture. Explained it to a mechanic and he said I need a new compressor and receiver dryer. Does this sound accurate to you guys? I am thinking about doing the work myself, I do have the vacuum pump to suck the system back down. Any advice would be appreciated!
