08 with 350k replaced both A/F and crank sensor still runs poorly and throws P0031 P0051 on both banks HELP
Sadly a check of relay (swapped with know good one) and new fuse DTC return. Thank you all the hunt continues.In that case, hopefully then the issue is what FJ said, the fuse or the harness.
To check the harness, unplug the sensors and unplug the engine ECU and test the wires using an ohm meter (look for the same color wires at the ECU connector).
In this link scroll down to page 70 for the engine ECU wiring diagram to guide you:
The O2 and A/F sensor wires are shown on pages 75 & 76. They are described on page 82 and their pin locations are detailed on page 83.
Norm
