Now Tie Rods Frozen
1 reading
1.8K views 13 replies 7 participants last post by  Sparky of NWO
#1 ·
So I took my FJ I bought a month ago for alignment because it pulled to the left but it needed new LCAs ... Did that with a friend in my driveway and was very proud of myself 😉
Unfortunately when I took it to the shop for alignment again, now it turns out the tie rod are rusted frozen and need to be replaced.
Is this a hard job to do yourself? Napa parts ok?
Thanks for advice,
Robert
#9 ·
I say that because if they can remove it to put a new one , they can adjust that one (unless tie rod has play in it).
I live in the rust belt and have yet to see a tie rod that can’t be moved with a little help from a torch. ( like mentioned already , maybe it’s bottomed out, but highly unlikely).
#10 ·
TheFrisco,
I agree with others that you're alignment shop simply did not want to put in the extra effort to sort out this situation. In your post, you did not include vehicle year or mileage. Since your LCA's were worn to the point of requiring replacement it's probable that your tie rod ends also have a lot of wear on them and even if adjusted, may have some play in the joints.
Replacing the tie rod ends is a simple job and relatively inexpensive. If it were my vehicle, I would just replace them.
#13 ·
SOLVED WITH YOUR GREAT FORUM ADVICE ... AGAIN
Sooo ... I took the car to another place, Good Year service place that is, and VOILA they could do it. Thanks for your push back on this and having me try a second place for alignment before I climbed underneath the car again and replaced the tie rods!!!
