I get a P0157 code and I've tried a bunch of things and I'm looking to see if someone has any ideas before I take my 2013 FJ with 130K miles to the Toyota repair shop.
I've done the following:
New spark plugs
New O2 & A/F sensors
Tried Cata-Clean
Tried O2 sensor spacers
Cleaned MAF sensor
None of this made any difference.
My diagnostics:
O2 sensors are working and I checked the wiring harness and I get the same readings on both banks so it's not a wiring issue.
Checked the temperature at the rear of the cats, the driver side was about 480 degrees and the passenger side was 510. Couldn't get a reading at the other end because of the heat shield.
When I look at the O2S2 B1 voltage it's around .7v to .8v The O2S2 B2 is at .04 when I'm idling. When I give it gas O2S2 B2 shoots up to .8v but then goes back down to .04v when I release the pedal.
When I look at the O2S1 B1 fuel trim its usually the same as O2S1 B2 but sometimes O2S1 B1 is double the value of B2.
The last thing I can think of is, is there a vacuum hose that could cause this? Or am I going to need a new cat?
New spark plugs
Tried Cata-Clean
Cleaned MAF sensor
My diagnostics:
