Status
Not open for further replies.
Bandi Mount Antenna Cable
14K views 0 replies 1 participant last post by  SwiCago
#1 · (Edited by Moderator)
To read the original full thread and post questions/comments, please go to http://www.fjcruiserforums.com/foru...m/forums/stereo-electronics/64532-routing-cb-wire-bandi-mount-through-door.html
I have seen many Bandi CB installs, so I will not show my entire install...just the part on how I routed my CB wire through the rear door.
Here you see my CB wire go into the door. I stepped drilled till the hole was big enough for the cable to fit.
Then I ran the wire back out the rear door.
I used single strand wire and feed it through the factory harness hose, then I taped my flexible CB cable to it. And pulled through into the cab of my FJ.
Ah, nice and clean. No holes in the factory harness hose and no way for the wire to flex or kink. :rocker:
After seeing this, I set mine up the same way (including a grommet). I drilled mine on the small angled section below the hinge. Two layers of metal in that location but very easy to drill.
Yep, it's two layers... but as you said...no big deal.
I did mine below the angle section, so the hinge would not be weakened.
btw do you have any walkthrought for getting the pannels all off so i can run my lines?
I had my panels removed, since I did the linex at the same time. You can attempt to do the coat hanger tip posted above by "in the trees" or follow these steps:
1)Remove seat back panel
2)Unbolt seat
3)Remove rear cargo floor panel
4)Remove Sill covers
5)Remove partially rear door jam rubber seal from frame.
6)Remove side panel. Screws at the bottom. Use a nylon prybar.
Takes about 30 minutes and gives you full access to cleanly run the cable and zip tie to main harness.
Status
You have insufficient privileges to reply here.
